Using playit agent on docker
I’m using your agent on a Docker and I’ve managed to connect successfully to my Minecraft server.
However, from security reason, I want to keep my servers inside internal Docker network and not to expose them to Host ports.
This raise me a problem when I’ve created the Tunnel - so instead of using 127.0.0.1 address - I need to use the internal Docker IP of the Minecraft server - which is constantly changing.
I tried to enter a host name - but got an “application error”.
Can you please enable host-name as an input for the tunnel and not just an IP ?
Thanks,
Daniel
I defined the networks in compose.yaml, set a static IP address for each service, and then set the IP address in playitgg web.
