Using Custom Domains with Squarespace Domains?
Is this even possible or do I also need to use cloudflare or something similar. I replaced my Domain Nameservers on squarespace but I can’t seem to connect if I set the tunnel to the host or a subdomain. Any help or ideas?
Are you able to nslookup your domain? is it resolving to the correct ip.
Ex.
nslookup my.domain.org 1.1.1.1
1.1.1.1 is using the cloudflare dns server to find your domain name ip.
NSlookup says no records for any type. I don’t which is weird because I really just replaced my cloudflare name servers. There a way to reset my dns or something?
Sounds like you didn’t setup your records you need on squarespace. I found this link to sqaurespace help section.
Here is a youtube video I found. Not sure if it’s really helpful…
The way your question sounds is that you are redirecting your squarespace domain traffic to playit.gg domain traffic.
