Unable to Host Multiple Severs From Same Device
I am trying to run two Bedrock Minecraft servers from the same host device using two UDP-only tunnels. Server A is configured to use port 19132 and Server B is configured to use 19142. Even though I am able to connect to both servers easily using the localhost address, when I try to connect using the proxy server’s IP, I can only connect to Server A (19132). To my knowledge this is not an issue with my computer’s firewall settings.
I’d be happy to share more if anybody has an idea of what the issue is.
Are you using docker? Or other management panel for minecraft server. Docker version doesn’t work good when you are using other port than 32. After deployment check container portnumber in server.propeties.
