Im trying to get a dedicated zomboid server up and running but I am not succeeding. My server unit connects to the site just fine and can generate tunnels, however the issue I am seeing is the tunnels do not work. I have tested a different tunneling service to verify that tunneling works with portchecker.co and my ports on those tunnels are open. When I check the status of the ports with the links provided in my tunnel, the ports are closed. I would prefer to use this service because I need UDP for zomboid and having a not changing ip would be nice.
I decided to verify this on windows and I have the same issue. I launch the playit app, go to the link, create a tunnel, and test the link. The ports are still closed for the ip and port generated in my tunnels on both windows and linux.
Update: I have tested more and UDP port tunnels specifically do not work. I opened a new tunnel for TCP and TCP+UDP and have open ports with those.
