Hi, I’m new here, i have a problem.
I’m using a velocity based server with paper, i want to run it 24/7 with playit.gg, but after 2 hours it stop the connection and i have to reload the script, why?
There is a limit in time?
Yeah, I don’t think that the limit get’s reached that quickly. But there is definitley a limit. Im actaully here because of the same problem, but I had my server open for about 2 months before it stopped…
interesting, that you only have 2 hours… I think that is a server side problem on your end.
There’s no set limit. On some internet connections there’s a an issue where the program will not reconnect properly after a distribution or a local ip rotation (cg-NAT). I haven’t been able to reproduce but it’s been reported by a good number of users so there’s a bug somewhere. Right now you’ll just need to restart the program. I recommend following the discord server to make sure you’re informed when new versions of the playit program come out. Hopefully it will be resolved in a future update.
thanks for the reply, I have solved by doing a VPN between my server and an Aws server and forwarding traffic between. It’s very simple and stable
