Teamspek with Playit
Hello there,
i’m trying to get Teamspek going with Playit but when i configure the ports i cant type more than one Port even thogh i typed Port count 3. I need to get the ports 2224TCP 9987UDP 30033TCP going with one IP adress. Does anyone know how that wuld be possible?
Thanks
When you create a TCP/UDP/Both tunnel you can configure port count. The ports are assigned are sequential and map to the first local port of your tunnel.
So if you’re assigned port 1024 with port count 3 you’ll have port: 1024, 1025, 1026. You’ll need to update your ports in your server config to be sequential too.
