Switching 1 tunnel to other agents programmatically
I want to be able to switch my tunnel to one agent to another automatically. Is there a way i can achieve this using the command line or .bat files?
I’m having to use different devices in different locations and i have the exact same server files on both of them (using git), i wanna be able to easily just click a button and everything runs smoothly.
will it work if i just give both PCs the same secret key on the secret path?
You will just break it.
There is an API in dev, so maybe wait and see if they will have an api for that
