Hello Playit Support,
I need help with a persistent connection issue using Playit.gg.
My Minecraft server works perfectly on localhost and LAN. Another computer can fully join and play on the server using its local IP address.
However, when players connect through Playit.gg, the server stays on “Pinging…” or “Connecting to server” and eventually times out.
My setup:
Public address: crispy.playit.plus:25565
Local IP: 127.0.0.1
Local port: 25565
Minecraft Java 26.3
Fabric Loader 0.20.1
Windows 11
Playit versions tested: 1.0.10 and 0.17.1
Errors found in my Playit logs:
control session expired; reconnecting reason=SessionNotSetup
failed to ping tunnel server
NetworkUnreachable
addr=[2602:fbaf:840::1]:5525
timeout waiting for pong
Playit recognizes incoming connections:
tcp_clients: New TCP Client
Windows also confirms that Playit establishes TCP connections to my Minecraft server:
LocalAddress: 127.0.0.1
LocalPort: 25565
RemoteAddress: 127.159.203.227
State: Established
However, the Minecraft client still times out, and the server sometimes reports:
MixeryFuFi lost connection: Disconnected
Things I have already tried:
New Playit tunnel
New Playit agent
Playit 1.0.10 and 0.17.1
Running Playit on two different computers
Different internet connection using a mobile hotspot
Windows Firewall rules
IPv4 settings
Fresh Minecraft server without additional mods
Confirmed that LAN multiplayer works perfectly
Verified the local IP and port
Restarted Playit and Minecraft multiple times
Nothing has fixed the issue.
Could you please investigate whether there is a problem with the Playit relay, TCP data forwarding, or my agent’s connection to your servers?
The TCP connection reaches Minecraft, but the Minecraft status response or login does not complete.
Please let me know what additional diagnostics you need.
Thank you!
