Hello! I’m trying to connect to the servers on the 0.9.3 program, but when i try to claim i get stuck on the loop of “Checking in 5 seconds…”.. Is this fixable? Thanks for any answer!
Check your firewall and makesure the correct port is open for the client, smthn like 34979/tcp or smth
Or test thats the problem by disabling the firewall entirely temporarily.
Its happening to me too when using the old version (which is better from my POV, it just provides more info and installation is not required)
