Some ISPs are blocking ply.gg
It looks like there’s a few ISPs still blocking one of our domains: “ply.gg”. This can cause the playit program not to work. If you’re running into this issue updating your DNS should resolve it: How to change your DNS server | playit.gg - support pages
If you’re a customer of Vodafone, VirginMedia or BT, reaching out to your ISP to complain would be really helpful :slight_smile:. I’ve reached out to them and they haven’t responded…
i could ask vodafone since its one provider is use
That would be awesome! :heart:
Dosent seem like vodafone is blocking it at least i can access it fine not sure if it worth contacting anyway to check?
Oh that’s good to know. Are you using the default DNS provider from Vodafone?
just relised i wasnt but its the same when i am which is nice
maybe its because im using mobile internet from vodafone?
Is this still the case?
