"secret failed verification moving to error state"
Trying to set up playit for Minecraft server and following entering the claim code the output says “secret failed verification after creating, moving to error state” I am using the unofficial playit-gg mod for fabric so it could absolutely be that but curious if anyone else had this issue and resolution. I did not have this problem in 1.20.
figured it out for those having the same issue. I first removed every mod except for the unofficial playit mod for fabric and the fabric api. When starting the server, compatibility was set to JAVA 17 (originally it was being set to JAVA 21). I was able to get my claim code and get everything started. I then moved all the mods back into the mods folder and everything loaded up fine. No idea what technical reason for this is but I do know that it fixed it and everything is working fine.
