- minecraft server: running on ubuntu with amp.
- playit.gg: installed with setup script, version
0.16.2. - dns: using google’s dns (
8.8.8.8and8.8.4.4). - tunnel status: playit reports tunnel is running and bound:
whole-flexible.gl.joinmc.link => 192.168.50.136:25565 (minecraft-java)
problem
- when running:
nslookup whole-flexible.gl.joinmc.link
the result is only:
Server: dns.google
Address: ......................::8888
→ there’s no ip address listed under the Name, only the domain.
- trying to connect in minecraft gives:
failed to connect: connection timed out: getsockopt
expectation
- nslookup should resolve
whole-flexible.gl.joinmc.linkto a playit ip and port (e.g.147.185.xxx.xxx:xxxxx). - right now, the domain never resolves to an ip.
question
- is this a dns propagation delay, a tunnel configuration issue, or something wrong with playit itself?
- why is
nslookupnot returning an ip even though playit says the tunnel is active?
