RAM usage going up as playit is running question
When you go into the Playit app, it looks like this (for me)
However, those lines of text never stop and they keep on refreshing. After a few hours, that document is hundreds of lines long. My RAM usage also seems to be creeping up as more lines are created. Does anyone know of any fixes, or will it stop using more RAM at some point?
(In the picture I blurred some lines out if it wasn’t obvious)
