Playit.gg Secret key location
Where does the playit.gg store the secret key? i want to reset it. How???
On windows its locaded at C:/Users/[user accont]/AppData/Local/playit_gg
[user accont] being the name of the user
Depends on the OS. You can find the file path by running
playit secret-path
in the command line / command prompt. You can delete all secret keys used by playit.gg on your system by running
playit reset
