Playit doesnt work on my rpi5
I’m trying to host a web panel and a MC Java server. The ports are correct, though nothing shows up on the website. I already tried making new tunnels, please help!
Sometimes for web, you need to use http instead of https.
Here are some common fixes to try:
Remember that domains include ip, so for example: test.ply.gg:5443
If domain fails, always try using the ip.
Make sure the node is connected.
For mc server:
Same fixes but also try using the plugin
