Not connecting to minecraft
Hi im Alessio im using playit.gg for about 1-2 years and i love no problems untill 1 week ago someone hijected destroying all my word in my minecraft server so i decided to reinstall but it dosent work i tried to reinstall playit.gg but nothing i ree check my port my ip i even tried to port forwarding but nothing playit.gg dosent want to leet me play my world local all work well and even port forwarding work but i dont want a port open , can someone help me? (sorry for my bad english )
Hi! I had a similar problem. Try checking if your local IP is correct in Playit (for Bedrock, something like 192.168.x.x and port 19132). Also make sure Windows Firewall allows the Bedrock server and Playit.
If Playit stops local connections, try joining using your local IP (192.168.x.x) inside your home network and use the Playit address only for friends outside your house.
To avoid people destroying your world again, enable whitelist/permissions and avoid sharing the server address publicly. Good luck!
I’ve had that issue once. I caused it by creating and deleting tunnels while keeping the same domain name attached to a game server. The playit.gg command console client probably freaked out when it happened. I couldn’t connect to my game server. Restarting the computer that contained the playit.gg agent window had fixed it, so idk.
im using zima os so Its not a problem of firewall i dont know what to do
