Minecraft Bedrock multiplayer connection failed (ZimaOS)
Hello internet. I’ve tried all the guides and videos and AI help online, but still can’t connect to my Bedrock server via playit.gg’s tunnel domain links. I keep getting the “Multiplayer Connection Failed’ error. I have my home server setup running ZimaOS, I’ve downloaded Crafty (not Crafty Controller by BigBearCasaOS is that matters) and in the app settings I had to change the Host: 8112 to 8113 (because 8112 was already in use). Then I downloaded the Playit Agent (again not the one by BigBearCasaOS). With my server created in Crafty under Config menu I have the IP Address set to my server local IP address (10.0.0.27) and the port as 19132. This allows me to connect and play on my server locally just fine. Jumping over to playit.gg, all that is set up on the free network. Under the Tunnel Configuration I have Local IP as 10.0.0.27, Local Port as 19132, and Proxy Protocol as None. Firewall is set to None. Active Connections says “You have 0 unique clients. Client are routed through free routing”. Also worth noting my Agent “Region” is set to Automatic, and “Allow IPv6” is set to Allow IPv6.
Any help would be greatly appreciated, thank you!
Bruh I got the same issue but with Java lol
