Linux agent not working?
I just signed up for playit.gg and installed the agent on my linux minecraft server and it just doesn’t seem to work. When I open the interface and look at logs, it is a barrage of this:
2023-08-04T16:46:56.470516Z  INFO playit_agent_core::agent_updater: agent config updated
2023-08-04T16:46:51.836587Z  INFO playit_agent_core::agent_updater: keep alive
2023-08-04T16:46:51.803972Z  INFO playit_agent_core::agent_updater: agent config updated
2023-08-04T16:46:46.770461Z  INFO playit_agent_core::agent_updater: register udp channel details details=SetupUdpChannelDetails { tunnel_addr: 209.25.140.2:5512, token: [0, 0, 0, 0, 0, 0, 5, 237, 0, 0, 0, 0, 0, 4, 53, 173, 0, 0, 0, 0, 0,
41, 19, 155, 100, 205, 43, 118, 177, 125, 30, 184, 231, 213, 81, 205, 204, 35, 204, 173, 242, 237, 177, 72, 140, 180, 4, 132, 7, 197, 158, 18, 39, 66, 80, 75, 162, 152, 133, 250, 208, 31, 230, 131, 13, 220, 231, 129] }
2023-08-04T16:46:46.731615Z  INFO playit_agent_core::agent_updater: agent config updated
2023-08-04T16:46:41.774450Z  INFO playit_agent_core::agent_updater: keep alive
2023-08-04T16:46:41.734342Z  INFO playit_agent_core::agent_updater: agent config updated
2023-08-04T16:46:38.795837Z  INFO playit_agent_core::udp_client: got UDP establish response
2023-08-04T16:46:36.698618Z  INFO playit_agent_core::agent_updater: agent config updated
2023-08-04T16:46:31.651156Z  INFO playit_agent_core::agent_updater: register udp channel details details=SetupUdpChannelDetails { tunnel_addr: 209.25.140.2:5512, token: [0, 0, 0, 0, 0, 0, 5, 237, 0, 0, 0, 0, 0, 4, 53, 173, 0, 0, 0, 0, 0,
41, 19, 155, 100, 205, 43, 103, 122, 159, 70, 108, 8, 190, 236, 80, 54, 240, 21, 167, 191, 223, 137, 169, 188, 205, 72, 69, 13, 37, 109, 34, 205, 84, 239, 62, 86, 82, 115, 120, 208, 31, 230, 131, 13, 220, 231, 129] }
2023-08-04T16:46:31.651091Z  INFO playit_agent_core::agent_updater: keep alive
2023-08-04T16:46:31.618376Z  INFO playit_agent_core::agent_updater: agent config updated
2023-08-04T16:46:26.646532Z  INFO playit_agent_core::agent_updater: agent config updated
2023-08-04T16:46:21.604682Z  INFO playit_agent_core::agent_updater: keep alive
2023-08-04T16:46:21.566713Z  INFO playit_agent_core::agent_updater: agent config updated
2023-08-04T16:46:16.541531Z  INFO playit_agent_core::agent_updater: register udp channel details details=SetupUdpChannelDetails { tunnel_addr: 209.25.140.2:5512, token: [0, 0, 0, 0, 0, 0, 5, 237, 0, 0, 0, 0, 0, 4, 53, 173, 0, 0, 0, 0, 0,
41, 19, 155, 100, 205, 43, 88, 116, 47, 1, 195, 70, 116, 222, 176, 21, 48, 254, 23, 43, 183, 32, 67, 7, 78, 234, 204, 123, 241, 156, 38, 106, 140, 20, 47, 116, 97, 60, 66, 208, 31, 230, 131, 13, 220, 231, 129] }
2023-08-04T16:46:16.510717Z  INFO playit_agent_core::agent_updater: agent config updated
2023-08-04T16:46:13.761623Z  INFO playit_agent_core::udp_client: got UDP establish response
2023-08-04T16:46:11.481055Z  INFO playit_agent_core::agent_updater: keep alive
2023-08-04T16:46:11.442742Z  INFO playit_agent_core::agent_updater: agent config updated
2023-08-04T16:46:06.414236Z  INFO playit_agent_core::agent_updater: agent config updated
2023-08-04T16:46:01.367292Z  INFO playit_agent_core::agent_updater: register udp channel details details=SetupUdpChannelDetails { tunnel_addr: 209.25.140.2:5512, token: [0, 0, 0, 0, 0, 0, 5, 237, 0, 0, 0, 0, 0, 4, 53, 173, 0, 0, 0, 0, 0,
41, 19, 155, 100, 205, 43, 73, 224, 141, 189, 213, 58, 203, 165, 209, 248, 161, 64, 49, 169, 209, 221, 150, 78, 215, 44, 215, 23, 151, 33, 43, 203, 32, 108, 188, 78, 241, 0, 58, 208, 31, 230, 131, 13, 220, 231, 129] }
2023-08-04T16:46:01.367267Z  INFO playit_agent_core::agent_updater: keep alive
2023-08-04T16:46:01.327696Z  INFO playit_agent_core::agent_updater: agent config updated
2023-08-04T16:45:56.392423Z  INFO playit_agent_core::agent_updater: lease claimed lease=ClaimLease { ip: 147.185.221.16, from_port: 2625, to_port: 2626, proto: Udp }
2023-08-04T16:45:56.360228Z  INFO playit_agent_core::tunnel_api: request signed req=SignedRpcRequest { content: Ok(ClaimLeaseV2(ClaimLease { ip: 147.185.221.16, from_port: 2625, to_port: 2626, proto: Udp })), auth: System { details:
RequestDetails { account_id: 275885, request_timestamp: 1691167556353, session_id: Some(2691995) } } }
2023-08-04T16:45:56.321693Z  INFO playit_agent_core::agent_updater: agent registered reg=AgentRegistered { account_id: 275885, session_id: 1517, session_timestamp: 1691167556329, signature: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0] }
2023-08-04T16:45:56.286815Z  INFO playit_agent_core::tunnel_api: request signed req=SignedRpcRequest { content: Ok(RegisterAgent), auth: System { details: RequestDetails { account_id: 275885, request_timestamp: 1691167556279, session_id:
Some(2691995) } } }
2023-08-04T16:45:56.209387Z  INFO playit_agent_core::agent_updater: agent config updated
2023-08-04T16:45:51.160152Z  INFO playit_agent_core::agent_updater: failed to claim lease error=NotRegistered
The web interface says the agent is connected, but shows “?ms” for latency and I am unable to connect to my minecraft server via the assigned dns name or ip address and port. I am still able to connect and play locally as well as over ddns with port forwarding externally.
Hey! Names Ti, I do some dev/server work on a few servers. Typically, what I have to do is change the IP in both playit.gg and server configs. If that doesn’t work, try deleting the files entirely and letting the server ‘reboot’ the data. It WILL change, so you’ll have to manually do some editing but for the most part, it’s self explainitory if you know what you are doing. Hope this helps!
