Is it possible to run the Playit client on Mikrotik devices?
Hello Playit community,
I am interested in running the Playit agent/client on a Mikrotik router. Since Mikrotik devices usually run on ARM architecture and have limited native package support, I was wondering if anyone has successfully run the Playit client on Mikrotik hardware or if it’s officially supported.
More specifically:
  • Is there a way to run the Playit client on RouterOS (Mikrotik’s OS) either natively or through containerization (Docker, etc.)?
  • Are there ARM-compatible builds of the Playit client that would work on Mikrotik devices?
  • Any tips or recommended approaches to get Playit running on Mikrotik hardware?
Thanks in advance for any guidance or advice!
