Hello i cant connect on my FiveM (Custom) server. it says
Coudnt connect : Failed to get info from server (tried 3 times)
= If you are thr server owner, are you sure you allowing UDP packets to and from the server ?
you need custom tunel for fivem set it to UDP or BOTH
