How to host a SCP SL server using playit.gg
I assume if your reading this you already know where all the files configs are on your server and that you already have the dedicated server installed.
A server hosted on playit cannot be verified and will not be shown on the server list. Atleast without extra steps.
  1. Have the playit program installed on your computer.
  2. Create a tunnel using the port 7777 udp.
  3. Set your ip in config_gameplay to your external ip.
  4. Do not touch the ipv4 setting. Keep it at 0.0.0.0
A possible way to get a verified server using playit this may not work as I haven’t tested it.
  1. Create a temporary port forward or trigger.
  2. Email the verification team.
    2.A The template for verification is, Server ip port and if it’s dynamic or static. Use the numerical ip shown in the tunnel settings.
  3. Once verified remove the port forward or trigger. and follow the steps above.
hello, i know this is old but i will ask anyways, is it possible for you to make an video guide since i followed the steps but it still dosent work
