I would like to add a custom domain that is .com but i cant add one you cant upload a custom domain
A way you could do it is do the normal playit tunnel from your PC to your playit IP, and then point your domain to your playit IP.
Tunnel IP’s remain static, so long as you don’t delete them, so it will always work if the server is in.
