so I clicked “hide the taskbar icon” and now theres no way to unhide it. how can I unhide it?
I found it. look up playit on windows search and run it (if its not already running) then go to task manager, find the task, open file location and run playitd-tray.exe and the tray icon will show up again. hopefully this solo discussion is kept in case someone else has the same issue
