I’ve just installed the plugin and set it up, but i get an error when starting the server:
[13:25:57 WARN]: [gg.playit.control.ChannelSetup] Got IO error working with :control.playit.gg/2602:fbaf:850:0:0:0:0:1, error : java.net.SocketException: Network is unreachable
and attempting to join from the address given:
[13:28:53 WARN]: [io.netty.channel.DefaultChannelPipeline] An exceptionCaught() event was fired, and it reached at the tail of the pipeline. It usually means the last handler in the pipeline did not handle the exception.
When i try to join in minecraft it just times out with no explanation
