Friends cannot connect
So I can join perfectly fine using amp primary endpoint ip and I give my friends the playit ip and we created a survival world and it worked perfectly fine. But then I add 2 mods and a custom world this is where things went wrong were on the correct version and his was set up just as mine but he would always get the java.net.socketexception.connection. Please help
Try a raw tcp tunnel if your mods don’t work.
