Ok, so i have custom cloudlfare domains, is there a way I can point them at the playit domain, because currently, my set up is not working
Pretty sure thats a premium feature if you wanna add your own custom domain names. You can try port forwarding using oracle’s always on free instances as a reverse proxy. Though its a bit of an involved process to set up.
I don’t think that you can change the port,
if you have a domain in cloudflare,
just add a cname that points to the generated domain of a tunnel.
