Hi ran into a problem after creating a tunnel Minecraft Java running a server on the kernel Mohist in which the port 25565 is prescribed and not prescribed the IP itself for some reason can not connect I have already tried everything all day killed to understand what the problem is but all the same, I turned off the firewall I added Java and Plait. gg to the rules for incoming connections and also added a rule for port 25565 but all is clear, also I checked if the IP is pinged it turns out it is pinged and also the IP has port 25565 open but even with a
it still does not connect I do not know why this information Internet I have 20 mb + speed is enough, and kaneshno for some reason then in the settings of the router I added to the “Virtual Servers” port 25565 and local ipi computer but even this did not help me, I am in a dead end I do not know what to do. Maybe the screenshot to something will show the answer.
I have the exact same issue, it seems to persist between restarts, changing tunnel settings and even operating systems (Persists on both linux and windows). The only way i found to “fix it” was to change the agents region to Asia (it connected me to sinagpore-1, if it even matters) (EDIT: India and south america also work for me, after trying them), but this isn’t a perfect fix, because of the high ping (i live in europe). I’m pretty sure this is some issue on playits part
