Can I setup playit.gg for BungeeCord?
so for a while I’ve been trying to set up playit for BungeeCord and nothing worked so far. plugins are not loading, I cant even install playit for linux (server on linux [using casaos, unbuntu]) if you know the solution to the problem let me know (:
bro it is simple but i know about windows i will try to help u dm me in discord name:
merockedushocked
u use discord? tell me ur name
