Agent stuck in SessionNotSetup reconnect loop — tunnel unreachable
My tunnel accepts TCP connections but never relays traffic to my local server. The agent repeatedly loses its control session immediately after connecting.
Account/agent details
  • Agent ID: 0739f97c-38a1-44de-bd1a-1e9879a38cb7
  • Agent version: 1.0.10, Windows
  • Tunnel: voidcity.playit.pub → 127.0.0.1:25565, Proxy Protocol: None
  • Paid plan
Symptom — control session loop (repeats every ~1s):
WARN maintained_control: control session expired; reconnecting reason=SessionNotSetup
INFO daemon: playit connected; tunnels loaded agent_id=0739f97c-38a1-44de-bd1a-1e9879a38cb7
tunnel_count=1 pending_tunnel_count=0 disabled_tunnel_count=0 account_status="verified"
Earlier IPv6 issue (already resolved by me):
The agent was pinging an IPv6 tunnel server on a host with no IPv6 connectivity (no global address, no ::/0 route):
ERROR address_selector: failed to send initial ping
error=Os { code: 10051, kind: NetworkUnreachable } addr=[2602:fbaf:85c:1::1]:5525
ERROR address_selector: failed to ping tunnel server
Setting Allow IPv6 → Only IPv4 cleared those errors. The SessionNotSetup loop continued unchanged. As feedback: the agent should fall back to IPv4 automatically rather than failing when no IPv6 route exists.
Local server verified working
A Minecraft status handshake against 127.0.0.1:25565 returns valid status JSON. The server listens on both 0.0.0.0:25565 and [::]:25565.
External behaviour
At 147.185.221.230:63283 the edge accepted TCP but closed the connection immediately when a Minecraft handshake was sent. After recreating the tunnel, that endpoint now times out entirely.
Already ruled out
  • Duplicate agents — only the background service runs, with an active control connection
  • Tunnel misconfiguration — verified 127.0.0.1:25565, Proxy Protocol None
  • Agent assignment — only one agent listed on the account
  • Stale allocation — tunnel deleted and recreated, no change
  • Local firewall — agent connects over loopback, which is exempt
Could you check why this agent cannot establish a stable control session?
Thanks.
I’m dealing with the same issue here
You can ignore the message if that’s the last line and nothing follows
