Agent shows up as offline even when running
I have an smp with my friends in minecraft. It works fine but after a day or two the IP address doesn’t work anymore. Going to my dashboard after logging in on playit.gg shows that the agent is offline. When I go to check the computer that is running the agent it still is running. Even though it shows as offline though, whenever I make changes to a tunnel, it updates on the agent’s view. One fix that does work is just closing the agent and reopening it but I don’t want to do this every time this happens as I want it to run 24/7
I have same problem for months and no one helps me. I checked almost everything and have no clue where is problem. Its outrages cause i was pay them for premium
