Add a way to make tunnels not report client's IP addresses
So like, let’s say that I use a Playit tunnel (thank you for the quality tunnels by the way, they seem pretty good) to forward a server for some friends to play on. At any time I can go to the analytics tab and see their public IPs. I cannot bring myself to not tell them that I can do that, and, I REALLY don’t want them to need to just “trust me” that I won’t peek on their IPs, this is not even for security reasons, just privacy reasons. I did notice that on the analytics tab it says later on it will become a premium-only feature, but a tunnel option that would need a new tunnel to be made to be reverted, AND some way to verify that so people also wouldn’t need to trust that you disabled it, would be very much appreciated. I have been trying to find a tunneling service after ngrok made their free plan have a very limited bandwidth, and this one is almost perfect, it would absolutely be perfect if something like this would be implemented
To be honest. Minecraft, Ark Survival, and more game server applications. Can see the ip the user connected with. Without even using playit.gg. This is just a nicety that playit.gg provides. I mean if you connect to any online service you are giving them your ip unless you are using a vpn. Sometimes you as a user can request a new from the ISP in your router config. Most the time it doesn’t happen. At least I can in my router. Hopefully this was helpful? This ip you connect to as well if you live in a dense populated area doesn’t help track someone down. My own isp ip is 5 towns over and maybe by that time my ip change and now it’s somebody else’s. There is anonymity but not a crazy amount. You would really have to track a person internet traffic from that ip to really diagnose who they are. Even then you don’t get enough information.
