What version of the playit program are you running?
v0.15.26
What country and city are you in?
USA, Bristol, Tennessee
What tunnel server are you connecting to? Dallas Datacenter 3
What is your ping? Where are you measuring this ping?
~120-300ms in game console
Any game i play without playit.gg my ping is a solid 30-40ms. When using Playit.gg my ping never falls below 110-120ms. Don’t understand why it’s forcing me to use a datacenter in Texas when I live on the east coast. The data center my ISP uses is out of Atlanta Georgia and works just fine.
What version of the playit program are you running? 0.15.26
What country and city are you in? Dumaguete City and Philippines
What tunnel server are you connecting to? Singapore-1
What is your ping? Where are you measuring this ping? 100ms and above
0.15.26 (linux)
USA, Austin
says dallas-3 in dashboard, but logs are pinging london
Client ping 100-200ms. Minecraft client, copy+paste pingtarget ip address (from playit.gg logs) into browser
0.15.26 (linux) What country and city are you in?
United States, Erie What tunnel server are you connecting to?
Miami-3 What is your ping? Where are you measuring this ping?
100-400 ms, from http://ping.gl.ply.gg
What version of the playit program are you running? (0.15.26 (64bit))
What country and city are you in? (Philippines, Tacloban City)
What tunnel server are you connecting to? (Singapore-1)
What is your ping? Where are you measuring this ping? (250-435ms) (measuring from in-game TABs plugin & Minecraftpinger.com) (game: Minecraft)
What version of the playit program are you running? (0.15.26)
What country and city are you in? (Athens, Greece)
What tunnel server are you connecting to? (mumbai-2)
What is your ping? Where are you measuring this ping? (300ms-400ms)
What version of the playit program are you running? plug-in
What country and city are you in? Mexico, Mexico City
What tunnel server are you connecting to? Dallas 3
What is your ping? Where are you measuring this ping? 200ms (average) cleanping (plugin)
My ping is fine there. If it helps at all, it is an SCP: SL server. For some reason Miami is the only one near me that support SCP: SL, but would it be faster/better to use a regular old UDP connection and set it to Chicago? Or would that not work?
Okay, Instead of using the SCP: SL preset which is limited to Miami, I’m just using a direct UDP so I can go to the Chicago datacenter. My ping dropped to 12-14 ms instantly, and I have seen no spikes so far.
What version of the playit program are you running? 0.17.1
What country and city are you in? Philippines
What is your ping? Where are you measuring this ping? 100 - 200ms (via Project Zomboid in game ping)
