Help with Playit
Why, when i connect playit, in my local server, and then, use the domain to connect with velocity, velocity says they cant connect with the server
Not sure what you mean by
normal setup \w velocity and playit is
playit —> velocity —> mc server
so if “velocity says they cant connect with the server” that would not involve playit. How do you have things setup?
